drawtoolbar can not activate
6980
12
04-15-2016 02:31 PM
JunxuanZhao
Currently, we  want to create a custom widget to draw polygon on the map(arcgis web appbuilder 1.3). But it shows that the Uncaught TypeError: Can not read property 'activate' of undefined. (In Widget.js file )
The related line is drawToolbar.activate(esri.toolbars.Draw.POLYGON);
Here is my code:
define(['dojo/_base/declare',
        'jimu/BaseWidget',
        'esri/urlUtils',
        'esri/config',
        'esri/map',
        'esri/graphic',
        'esri/tasks/RouteTask',
        'esri/tasks/RouteParameters',
        'esri/tasks/FeatureSet',
        'esri/symbols/SimpleMarkerSymbol',
        'esri/symbols/SimpleLineSymbol',
        'esri/Color',
        'dojo/_base/array',
        'dojo/on',
        'dojo/dom',
        'dojo/domReady!',
        'dijit/registry',
        'dijit/layout/BorderContainer',
        'dijit/layout/ContentPane',
        'dijit/form/HorizontalSlider',
        'dijit/form/HorizontalRuleLabels',
        'esri/toolbars/draw',
        'esri/tasks/GeometryService',
        'esri/symbols/SimpleFillSymbol',
        'esri/tasks/DataFile',
        'dojo/_base/connect'
    function(declare, BaseWidget,urlUtils, esriConfig, Map, Graphic, RouteTask, RouteParameters,
        FeatureSet, SimpleMarkerSymbol, SimpleLineSymbol,
        Color, array, on, dom, registry,
        Draw, GeometryService,SimpleFillSymbol,DataFile,connect
     return declare([BaseWidget], {
      baseClass: 'jimu-widget-MyWidget',
      startup: function(){
        var map, Draw, routeTask, routeParams, routes= [];
        var drawToolbar;
        var geometryService;
        var stopSymbol, barrierSymbol, polygonBarrierSymbol,routeSymbols;
        var mapOnClick_addStops_connect, mapOnClick_addBarriers_connect,mapOnClick_addPolygonBarriers_connect;
        geometryService = new        GeometryService("https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        map = this.map;
        routeTask = new RouteTask("https://route.arcgis.com/arcgis/rest/services/World/Route/NAServer/Route_World");
        routeParams = new RouteParameters();
        routeParams.polygonBarriers = new FeatureSet();
        routeParams.outSpatialReference = {"wkid":102100};
       var polygonBarrierSymbol= new esri.symbol.SimpleFillSymbol();
        routeSymbols = {
          "Route 1": new SimpleLineSymbol().setColor(new Color([0,0,255,0.5])).setWidth(5),
          "Route 2": new SimpleLineSymbol().setColor(new Color([0,255,0,0.5])).setWidth(5),
          "Route 3": new SimpleLineSymbol().setColor(new Color([255,0,255,0.5])).setWidth(5)
        on(dom.byId("addpolygonBarriersBtn"), "click", addpolygonBarriers);
        on(dom.byId("clearpolygonBarriersBtn"), "click", clearpolygonBarriers);
    function createToolBar(){
        drawToolbar = new esri.toolbars.Draw(map);
        drawToolbar.on("draw-end", addToMap);
        function activateTool(){
        map.hideZoomSlider();
        function addToMap(evt) {
          drawToolbar.deactivate();
          routeParams.polygonBarriers.features.push(
          map.graphics.add(new esri.Graphic(evt.geometry, polygonBarrierSymbol)) );
        var node = dojo.byId("addpolygonBarriersBtn");
        dojo.connect(node, "click", activateTool);
     map.on("load", createToolBar);
      //Begins listening for click events to add polygonbarriers
        function addpolygonBarriers() {
          removeEventHandlers();
          mapOnClick_addPolygonBarriers_connect = on(map, "onclick", addPolygonBarrier);
      //Clears all polybarriers
        function clearpolygonBarriers() {
          for (var i=routeParams.polygonBarriers.features.length-1; i>=0; i--) {
            map.graphics.remove(routeParams.polygonBarriers.features.splice(i, 1)[0]);
       // Add Polygon
        function addPolygonBarrier(evt) {
            var drawEnd_connect = dojo.connect(drawToolbar, "onDrawEnd", function(geometry) {
            routeParams.polygonBarriers.features.push( map.graphics.add(new esri.Graphic(geometry, polygonBarrierSymbol)) );});
        function removeEventHandlers() {
          if (mapOnClick_addPolygonBarriers_connect) {
            mapOnClick_addPolygonBarriers_connect.remove();
Tags (1)
JunxuanZhao
At first, we found a related code on https://community.esri.com/thread/88541#comment-366869 , but it uses http://js.arcgis.com/3.8/js/esri/css/esri.css. Then we modified this code to 3.16 version(See the attachment 1). Next, we want to make it as a widget.
Now we have two versions, the first one, it can do routing but can not draw the polygons; the second one(according to your guide), it can draw the polygon, but can not do the routing.
Junxuan
RobertScheitlin__GISP
Juxuan,
  OK here is the edited and fully working version of your widget:
JunxuanZhao
Hi Robert,
Thanks for your help during these days and now the code works quite well! You help our project a lot!
Junxuan
