Does the latest LocalLayer widget work with WAB 1.3
4175
02-18-2016 08:35 AM
EricVenden
I downloaded the latest version of the LocalLayer widget (1.2.2-last upated on 11/17/2015).  I am attempting to use it with WAB 1.3 and am finding some issues.
Is version 1.2.2 compatible with WAB 1.3?
Thanks
Eric V
Gurnee, IL
RobertScheitlin__GISP
Eric,
   I have it working just fine in WAB 1.3 after follow the advice in this thread:
Re: LocalLayerWidget and AccessifizrWidget
Eric,
EricVenden
Hi Robert,
I have made the 2 tweaks to the code (config.json & LayerInfos.js).
Creating a new app results in the following view in the Widgets tab - I cannot "edit" the LocalLayer widget.
The LocalLayer widget shows up as "6"....when I click on it, it pops up the widget list....none of which are the LocalLayer widget
Eric,
   Sounds like you need to go to this url and follow the steps for setting up the widget
GitHub - cmndrbensisko/LocalLayer: The LocalLayer Widget for ArcGIS Web AppBuilder is intended to al...
Because from the looks of it you have something wrong in the setup.
EricVenden
I went back and did a fresh "install" of WAB1.3, and made the appropriate changes to the 2 files - but this time I changed the config.js file in the "Default" app under the "predefined-apps" folder.  My last attempt I only updated the config.js under the stemapp folder.  I then created a new application and the widget showed up properly.
Eric,
   Glad you got it working. Don't forget to mark this as answered.
