Distance and Direction widget adding layers
1720
05-09-2020 09:47 PM
divisionodt
Hi i'm trying to use the distance and direction widget on my application in which i groupped my layers using the groupping widget option but now whenever i use the mentionned widget it add layers in all the listed layers
Is there any possibility to prevent adding those layers into the Layer List, Thanks in advance
KevinGonzago
@divisionodt Initially the widget created lines, circles, ellipses and range rings as simple graphics in a graphics layer that didn't show up in the Layer List widget. It was enhanced in the previous release where these geometries are now saved in feature layers which allows users to publish/share results as feature services in their orgs. Creating these features in client-side feature layers does create entries for those layers in the Layer List widget. I don't think you can hide layers in that widget.
bjl2Nsight
Has there been any changes to this?
We want to measure our direction and this is the only method we've found. The layers are very annoying.
