disable pop-up for the query result layer ?
8037
20
05-15-2016 03:15 PM
IbrahimMohammed_Ahmed
can i manipulate the source code for the query widget to disable info-window for the results layer the query creates ?
JasonStanton__GISP
So this is a Web Map issue not a Portal issue... and the only way to prevent this is to disable all configured popups in the Web Map?
RobertScheitlin__GISP
Jason,
  Does the empty popup not disappear as a few seconds of displaying "Searching" then "No information available"?
JasonStanton__GISP
It does not dissapear, nor does it display "Searching".  Attached is a screen shot.
Does it only do that if you open the query widget and do a query first?
JasonStanton__GISP
Yes.  I open the widget, run the query, then select a record and the blank info window appears.
So my question really was does it not show that blank popup if you do not open the Query widget
JasonStanton__GISP
Sorry, it does not show a blank popup if I do not open the query widget
Jason,
  OK. Now I understand. You are getting the empty popup when you click on a query result in the widget. So to disable that you have to comment out this line in the SingleQueryResult.js _onResultsTableClick function:
this.map.infoWindow.show(centerPoint);
JasonStanton__GISP
First - my apologies for not making my issue clear in the beginning
Second - thank you for the 8,761st time... I very much appreciate your help!
One point of note for anyone else that comes across this post - the line of code to comment out is in the SingleQueryResult.js file not Widget.js.
Jason,
   Correction made to my previous post.
