Disable mouse scroll in an embedded web mapping application
4204
04-11-2022 02:45 PM
AJ_devaccount
I've created a web mapping application using WAB, and have embedded it into an ArcGIS Hub page. Is it possible to disable scrolling on the map using the mouse wheel? Anytime a user passes over the map, instead of scrolling up/down the page, it zooms in/out of the map, which can be a disruptive experience.
I've created it using the WAB, and unfortunately I'm not familiar with creating it using developer tools.
Edit: It seems that disabling it using WAB or embed settings in Hub doesn't work. Can I download the code of the application, and change it that way?
Thanks very much for your help.
BryndaHatch
I found this other thread that explains that turning the Allow Scrolling to No only turns it off for embedded apps like StoryMaps.  https://community.esri.com/t5/arcgis-hub-questions/no-allow-scrolling-for-application-card-not/m-p/1...
However, if you really want to turn it off, I found this other page that explains how: https://developers.arcgis.com/javascript/latest/sample-code/view-disable-zoom/
BryndaHatch
If you embedded your WAB in the Hub page using an iframe, then look for the setting called Allow Scrolling and turn it off.
https://doc.arcgis.com/en/hub/sites/embed-video-social-media-and-iframes.htm#ESRI_SECTION1_C30D73392...
The link above is for the help doc on this.
AJ_devaccount
thanks @BryndaHatch! I did try that option, but somehow it still auto scrolls if the cursor is on the map.
BryndaHatch
