Disable editing on Feature layer, while being able to add new related records, and edit existing related records.
2491
06-11-2018 11:53 AM
AndresCastillo
I would like to disable editing on the Feature Class completely, while being able to add new related records, and edit existing related records.
The structure is as follows:
·         FC
·         related to
·         Inspection History Table
·         via Parent Global ID, Global ID Data Type/Child Guid, Guid Data Type
·         relate to
·         Attachment table
These are published as a feature access service using ArcGIS server 10.4.1.
In the Edit Widget:
When I make the layer editable, and enable 'disable update geometry', then also make the table editable:
      This still allows me to create new points from the layer, add new related records, and edit existing related records.
When I make the layer not editable, then make the table editable:
      Neither the layer, nor the table are editable.
In the Smart Editor Widget:
For the FC layer:
Disable the ‘editable’ option
Enable the ‘Update Only’ and ‘Disable Geometry Editing’ options.
Leave ‘Allow Delete’ disabled
For the related Table:
Enable the ‘editable’ option,
Leave ‘Update Only’ and ‘Allow Delete’ disabled
Instruct users to either launch smart editor widget from the main popup, or if launch from the related record popup, must click ‘back’ button to add related record.
Only the Smart Editor Widget accomplished my goal of:
'I would like to disable editing on the Feature Class completely, while being able to add new related records, and edit existing related records.'
Why this difference?
I am on WAB DE 2.8
AndresCastillo
Any tips, Robert Scheitlin, GISP Champion ?
RobertScheitlin__GISP
Andres,
   I don't know why there is a difference, but it sounds like a bug that needs to be reported to esri tech support.
AndresCastillo
Thank you Robert
AndresCastillo
Note that I am able to replicate this same issue in AGOL WAB.
Also, In WAB DE 2.8, I am able to check the one field I want to display from the fc, then 'ok'
This works great.
But when I try to do the same in AGOL WAB, it doesn't let me hit 'ok'
The consequence of that is that the user ends up seeing a lot of fields in the fc that are unnecessary for this application, but useful for other applications.
I sure wish that the smart editor widget would honor the popup settings I configured for the fc in the web map.
