Custom python toolbox as a geoprocessing service fails
1100
02-24-2022 08:10 AM
GrantHaynes
Howdy,
I have a very simple python toolbox that takes in an excel sheet that contains lithology information and a kml/kmz file that contains borehole locations, processes them and appends them to a specified point and table featureclass. The tool works great in pro, with no issues. However, I published the tool out to my arcgis portal, published a point and table layer to go with it, wrapped them all up in a web app and it fails to add any information to the web layers. Does anyone here know what's going wrong?
Code:
import arcpy, os, openpyxl, shutil, time
from arcgis.gis import GIS
from arcgis.features import FeatureLayerCollection
class Toolbox(object😞
    def __init__(self😞
        """Define the toolbox (the name of the toolbox is the name of the
        .pyt file)."""
        self.label = "Toolbox"
        self.alias = "toolbox"
        # List of tool classes associated with this toolbox
        self.tools = [BoreholeArchive]
class BoreholeArchive(object😞
    def __init__(self😞
        """Define the tool (tool name is the name of the class)."""
        self.label = " Simple Borehole Archive Tool"
        self.description = ""
        self.canRunInBackground = False
    def getParameterInfo(self😞
        """Define parameter definitions"""
        param0 = arcpy.Parameter(
        displayName="Input KML/KMZ File",
        name="input_kml",
        datatype="DEFile",
        parameterType="Optional",
        direction="Input")
        param1 = arcpy.Parameter(
        displayName="Input excel file",
        name="input_excel",
        datatype="GPType",
        parameterType="Required",
        direction="Input")
        param2 = arcpy.Parameter(
        displayName="Borehole point featuer layer to append",
        name="output_borehole_point",
        datatype="DEFeatureClass",
        direction="Input")
        param3 = arcpy.Parameter(
        displayName="Table to append",
        name="output_lithology_table",
        datatype="DETable",
        direction="Input")
        params = [param0, param1, param2, param3]
        return params
    def isLicensed(self😞
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters😞
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a parameter
        has been changed."""
        return
    def updateMessages(self, parameters😞
        """Modify the messages created by internal validation for each tool
        parameter.  This method is called after internal validation."""
        return
    def execute(self, parameters, messages😞
        kml_kmz_filepath = parameters[0].valueAsText
        excel_filepath = parameters[1].valueAsText
        output_fc = parameters[2].valueAsText
        output_table = parameters[3].valueAsText
        # Get folder paths, do any work relating to temp files here
        arcpy.AddMessage("Starting")
        cwd = arcpy.env.scratchFolder
        temp_excel_file_path =  os.path.join(cwd, "temp.xlsx")
        if os.path.exists(temp_excel_file_path😞
            os.remove(temp_excel_file_path)
        kml_folder = os.path.join(cwd, "kml_conversion")
        if os.path.exists(kml_folder) == False:
            os.mkdir(kml_folder)
        kml_items = os.listdir(kml_folder)
        for kml_item in kml_items:
            if ".gdb" in kml_item:
                arcpy.Delete_management(os.path.join(kml_folder, kml_item))
            else:
                os.remove(os.path.join(kml_folder, kml_item))
        temp_gdb = os.path.join(cwd, "borehole_temp.gdb")
        if arcpy.Exists(temp_gdb😞
            arcpy.Delete_management(temp_gdb)
        # clean row 1 of the excel file
        interval_column_names = ["0_5",
        "5_10",
        "10_15",
        "15_20",
        "20_25",
        "25_30",
        "30_35",
        "35_40",
        "40_45",
        "45_50",
        "50_55",
        "55_60"]
        # Create a copy of the input excel sheet
        shutil.copy(excel_filepath, temp_excel_file_path)
        wb1 = openpyxl.load_workbook(filename=excel_filepath)
        ws1 = wb1.worksheets[0]
        wb2 = openpyxl.load_workbook(filename=temp_excel_file_path)
        ws2 = wb2.create_sheet(ws1.title)
        for row in ws1:
            for cell in row:
                ws2[cell.coordinate].value = cell.value
        wb2.save(temp_excel_file_path)
        wb = openpyxl.load_workbook(temp_excel_file_path)
        sheet = wb.active
        i = 1
        bid_tracker_no_column = 1
        id_column = 2
        # Clean column names
        current_interval = ""
        while i < sheet.max_column +1:
            cell = sheet.cell(1, i)
            column_name = cell.value
            column_name = column_name.strip()
            column_name = column_name.replace("'", "")
            column_name = column_name.replace(".", "")
            column_name = column_name.replace("-", "_")
            column_name = column_name.replace(" ", "_")
            column_name = column_name.replace("/", "_")
            if column_name == "Bid_Tracker_No":
                bid_tracker_no_column = i
            if column_name == "ID":
                id_column == i
            if column_name in interval_column_names:
                current_interval = column_name
            if current_interval == column_name:
                cell.value = "Int_{}".format(column_name)
            elif current_interval == "":
                cell.value = column_name
            else:
                cell.value = "Int_{}_{}".format(current_interval, column_name)
            i += 1
        # Run through the spreadsheet and create the foriegn keys
        master_id_column = sheet.max_column +1
        cell = sheet.cell(1, master_id_column)
        cell.value = "Bid_Tracker_No_and_ID"
        i = 2
        while i < sheet.max_row + 1:
            id_cell = sheet.cell(i, id_column)
            bid_tracker_cell = sheet.cell(i, bid_tracker_no_column)
            master_id_cell = sheet.cell(i, master_id_column)
            if bid_tracker_cell.value and id_cell.value:
                master_id_cell.value = "{}-{}".format(bid_tracker_cell.value, id_cell.value)
            else:
                arcpy.AddWarning("Bad Bid_Tracker_No_and_ID in lithology layer, replace 99999 values with correct value")
                master_id_cell.value = 99999
            i+=1
        wb.save(temp_excel_file_path)
        # Create a temp gdb to hold temp data
        arcpy.management.CreateFileGDB(cwd, "borehole_temp.gdb")
        arcpy.env.workspace = temp_gdb
        # Convert the excel sheet into a gdb table
        lithology_table_path = os.path.join(temp_gdb, "Lithology")
        arcpy.conversion.ExcelToTable(temp_excel_file_path, lithology_table_path)
        # Add the tracking fields
        arcpy.AddField_management(lithology_table_path, "created_user", "TEXT")
        arcpy.AddField_management(lithology_table_path, "created_date", "DATE")
        arcpy.AddField_management(lithology_table_path, "last_edited_user", "TEXT")
        arcpy.AddField_management(lithology_table_path, "last_edited_date", "Date")
        # Update the online table
        arcpy.Append_management(lithology_table_path, output_table, "NO_TEST")
        arcpy.AddMessage("Lithology records added")
        # If a kml filpath is given then make the kml/kmz into a gdb and pull out the
        # needed information and push it into the temp gdbt
        if kml_kmz_filepath != None:
            arcpy.conversion.KMLToLayer(kml_kmz_filepath, kml_folder)
            arcpy.AddMessage("KML/KMZ converted")
            temp_folder_contents = os.listdir(kml_folder)
            kmz_gdb = ""
            for item in temp_folder_contents:
                if 'gdb' in item:
                    kmz_gdb = os.path.join(kml_folder, item)
            kml_points_fc = os.path.join(kmz_gdb, "Points")
            # If the kml has been processed extract out the relevant information into a new point feature class
            # in the temp geodatabase
            if arcpy.Exists(kml_points_fc😞
                new_points_fc = os.path.join(temp_gdb, "Boreholes")
                arcpy.CreateFeatureclass_management(temp_gdb, "Boreholes", "POINT")
                arcpy.CopyFeatures_management(kml_points_fc, new_points_fc)
                arcpy.AddField_management(new_points_fc, "Bid_Tracker_No_and_ID", "TEXT")
                arcpy.AddField_management(new_points_fc, "Bid_Tracker_No", "TEXT")
                arcpy.AddField_management(new_points_fc, "ID", "TEXT")
                arcpy.AddField_management(new_points_fc, "created_user", "TEXT")
                arcpy.AddField_management(new_points_fc, "created_date", "DATE")
                arcpy.AddField_management(new_points_fc, "last_edited_user", "TEXT")
                arcpy.AddField_management(new_points_fc, "last_edited_date", "Date")
                # Pull the information from Name and put it in Bid_Tracker_No_and_ID
                with arcpy.da.UpdateCursor(new_points_fc, ["Name", "Bid_Tracker_No_and_ID"]) as cursor:
                    for row in cursor:
                        if row[0] != None:
                            row[1] = row[0]
                        else:
                            arcpy.AddWarning("Bad Bid_Tracker_No_and_ID in boreholes layer, replace 99999 values with correct value")
                            row[1] = 99999
                        cursor.updateRow(row)
                del cursor
                arcpy.AddMessage("Primary Keys Created")
                # Delete unneeded fields
                # new_points_fc_fields = arcpy.ListFields(new_points_fc)
                # for field in new_points_fc_fields:
                #     if field.name not in ["OBJECTID", "Shape", "Bid_Tracker_No", "ID", "Bid_Tracker_No_and_ID", "created_user", "created_date", "last_edited_user", "last_edited_date"]:
                #         arcpy.DeleteField_management(new_points_fc, field.name)
                # arcpy.AddMessage("Extra KML/KMZ fields removed")
                # Since there was a kml update the web point layer
                arcpy.Append_management(new_points_fc, output_fc, "NO_TEST")
                arcpy.AddMessage("Borehole locations added")
            else:
                arcpy.AddWarning("No points found in kml/kmz, kml/kmz not processed")
            arcpy.AddMessage("Complete")
            time.sleep(10)
        return
What it looks like in WAB pre run:
After running:
