Change the default highlight symbol and zoom level for URL parameter query results
6969
12
09-23-2016 03:08 AM
Pin_PointAlerts
I am looking to modify the default style symbols for a query result, where the query is generated using URL parameters, eg;
http://localhost/application/?query=LayerNameJSONCode_1234,ATTNAME,ATTVALUE
Right now the basic cyan outline (no fill) exists and I cannot find a way to edit this. Also, the zoom level is 100% surrounding the polygon with no buffer area displayed for local context. We are looking to change the display parameters and zoom levels to that we can link to the correct feature in our application from a URL query via an external application. The major problem for us is that the Cyan is difficult to interpret against neighbouring features.
I've tried tracing the setting back through the MXD, AGOL Map and the Web App Builder (V2). No joy.
Thanks a lot.
BC
RobertScheitlin__GISP
Dave,
  One solution would be to expand the extent by a factor.
var resultExtent = jimuUtils.graphicsExtent(features);
map.setExtent(resultExtent.expand(1.2)); //1.2 means expand 20%
else
map.setExtent(resultExtent).then(function(){
  map.setScale(somescale);
But this would be zoom and zoom again.
daveostrander
Thanks so much! I will experiment with that. You are right might feel a bit jerky.
daveostrander
Hi Robert,
Expand is perfect!!! Exactly what I was looking for!  map.setExtent(resultExtent.expand(1.4)); is what I went with.
******Correct answer******
