Is there a way to put a widget within a popup in an Web App for ArcGIS?
484
01-17-2019 01:56 PM
TravisPreston2
The chart widget within Web AppBuilder is trying to graph all of the data points within an extent. Also, some of the points are stacked on top of each other because they are nested wells. When you click on a point within the map the popup lets you use arrows to go through each feature. Id like to be able to select a point, click the arrow until the feature I want is selected, and then have a graph made for that data point and not all data points within the extent.
