Can attribute table results be limited to map extent by default?
12612
21
02-05-2015 10:29 AM
MikeMartin
I do not want all records of a layer's attribute table to be loaded into the attribute table. Can the config_Attribute Table.json be modified to limit results to the map extent by default, and only when the layer's scale range has been reached? Thanks.
RobertScheitlin__GISP
Michael,
   OK in 1.2
  • line 143: this.matchingCheckBox = null; should Not be changed.
  • line 145: this.matchingMap = false; should be changed to true
  • line 1031: checked: false, should be changed to true
Tested and working in WAB 1.2
MichaelRobb
Honored Contributor
That worked!
File:  Server\apps\##\widgets\AttributeTable\Widget.js
Change code this.matchingMap = false;  TO this.matchingMap = True;  (ln 145 in version 1.2)
Change code checked: false,  TO checked: true, (ln 1031 in version 1.2)
Filter my Map Extent is enabled (now default) when application is launched.
