Trying to figure out in what release of Web AppBuilder (Developer Edition) the fix for Esri BUG-000115990 will be implemented in.
I didn't see any information about this on the Bug support page.
Solved! Go to Solution.
Robert is right. The issue has been fixed in the latest online September update and will be picked up by Dev Edition 2.10 in October. 2.10 beta version will be available very soon in the Early Adopt Program (EAP). I will paste a link once it is available.
BUG-000115990: While using the Jewelry Box theme with the side pane..
is says version 6.3 in the link
bug reports are so useful aren't they ![]()
Well, I'm experiencing the bug in WAB version 2.8. So I don't really believe it was fixed at 2.6, unless they reintroduced it at version 2.8.
Patrick,
Sorry I had some bad info. AGOL WAB 2.10 is version 6.3. You can check this by using
which returns
{"currentVersion":"6.3"}
So was my link correct ? or was that a misdirect? since it had the actual bug number?
Dan,
Your link is correct. Original post is asking in which developer edition the fix will be. Sometimes users do not know the version comparison between embedded version in AGOL and developer edition. Once the fix is in AGOL, new version of develop edition following up the AGOL update will be released in 2-3 weeks, including the fixes and new features in AGOL. Thanks for the help!
