Auto-refresh attribute tables when the associated layer is set to a refresh interval
4160
03-23-2015 09:31 AM
JasonKlrkland
New Contributor II
Just a feature request to have the attribute tables auto-refresh when their associated tables are set to a refresh interval.
A specific use case is a police/fire vehicle and call tracker where new calls and vehicles are updated on the map via a refresh interval on their layer.  Currently, only the map updates, not the associated attribute table.
Tags (1)
StanMcShinsky
Occasional Contributor III
Jason Klrkland​,
If you go into the \widgets\AttributeTable\Widget.js file and add
setInterval(lang.hitch(this, this.onRefreshButton),3000); // setInterval(expression,milliseconds);
I added it right after the refresh button is called around line 1492, but I am sure it could be called other places as well. It would look something like this.
        this.refreshButton = new Button({
          label: this.nls.refresh,
          showLabel: true,
          iconClass: "esriAttributeTableRefreshImage",
          onClick: lang.hitch(this, this.onRefreshButton)
        toolbar.addChild(this.refreshButton);
This calls the refresh of the attribute table every 3 seconds. I did notice that if the attribute table has lots of features or tables to load it takes a little longer. Also this will continue to refresh the attribute table even when it is closed.
This would be great to have in the AGOL version too.
With a little more work I am sure you could add it as a button to toggle the refresh option.
-Stan
StanMcShinsky
Also if you did not want to see the little image flashing every time it reloads the just add this in the onRefreshButton function
this.showRefreshing(false);
like this around line 1555
      onRefreshButton: function() {
        if (this.layersIndex > -1) {
          if (this.grids[this.layersIndex]) {
            this.grids[this.layersIndex].clearSelection();
          if (this.graphicsLayers[this.layersIndex]) {
            this.graphicsLayers[this.layersIndex].clear();
          this.setSelectedNumber();
          if (this.config.layerInfos[this.layersIndex]) {
            this.config.layerInfos[this.layersIndex].loaded = false;
            this.startQuery(this.layersIndex, this.config.layerInfos[this.layersIndex].extent);
        this.showRefreshing(false); //added this
-Stan
