Attribute widget initial position change in WAB 2.1
1407
09-07-2016 04:24 PM
ChadRicks
In WAB 1.2 in the attribute table widget.js file i can adjust the default size of the attribute table by changing
setInitialPosition: function() {
var h, b;
if (this.position.height) {
h = this.position.height;
} else {
h = document.body.clientHeight;
h = h / 5;
In WAB 2.1 it is different and i'm not sure what to change to make the default size smaller.
RobertScheitlin__GISP
Chad,
   Now that calculation is in this function:
      _getNormalHeight: function() {
        var h = document.body.clientHeight;
        return window.appInfo.isRunInMobile ? h / 2 : h / 3;
