Anybody having problems with their custom geocoder working in arcgis online? Works fine with Arcmap.
2616
6
03-16-2016 08:02 AM
ChetShuler
Over wrote the geocodiong service and updates do not work with web apps. Works fine inside arcmap. Must be missing something simple.
RobertScheitlin__GISP
Chet,
  No, I have not had a problem with this and use a custom geocoder all the time. Have you cleared your browsers cache and re-started your geocode service?
ChetShuler
Yes. Also re-booted server and refreshed the service. I can load the geocoder from the service inside arcmap works fine. The web apps still did not take updates..
Chet,
Have you tried removing your custom geocode service from WAB and saving and closing and re-adding it?
ChetShuler
Just tried it. No good..
Sorry to say it sounds like a tech support call then.
ChetShuler
Thanks for the quick response and effort.
