Add your own rest end points services to layerlist
4618
7
09-10-2014 02:55 PM
TysonTaylor
is there a way to do this?
AnthonyGiles
Honored Contributor
Have a look at Roberts post here:
Do you have to use AGOL to use WAB?
TysonTaylor
We have our on internal portal beta 10.3
AnthonyGiles
Honored Contributor
In that case you add the rest endpoints into your web map then create your web application using that web map id.
TysonTaylor
Ok I’ll give that a try. Thanks
larryzhang
Within AppBuilder, to access map services & image services from our ArcGIS servers, it looks that we should go through the widget (like basemap gallery widget), because all applications created by Web AppBuilder must be based on a web map from a portal, such as ArcGIS Online or Portal for ArcGIS.
As we known, Portal for ArcGIS or ArcGIS Online can directly consume those services from organization ArcGIS Servers...
Team, is it correct?
Pls advise...
larryzhang
tyson,
it is confirmed by thread at https://community.esri.com/message/397707#397707
TysonTaylor
Great thank you
