Add data widget
1060
19
11-20-2018 01:18 PM
GarethYoung1
Is there a way to customise the add data widget so that it doesn't take you to the AGOL or portal page for the metadata?
It would be ideal if the description etc appeared in the widget or in a pop-up box.
Many thanks
Gareth
Robert Scheitlin, GISPAdri2c Pérez Beneito
RobertScheitlin__GISP
What custom widget are you using?
GarethYoung1
I could send it to you if that helped?
Sure
GarethYoung1
How can I do that?
In your reply click on the "use advanced editor" link (upper right hand corner). then when you get the advanced editor you will see a attach link in the lower left corner.
GarethYoung1
Robert,
I don't seem to have an advanced edit option
You will not see the use advanced edit option when you are in your inbox. You actually have to open the thread by double click on the thread in your inbox to open it then you will see the option.
GarethYoung1
Thanks Robert.  I've added the attachment.
I believe it lets you search more than one group as curated content and displays the information as part of the widget itself.
However, when I deploy it, I get error messages to say it can't find the portal/agol.
Gareth,
  This widgets code in from back in WAB 2.1 and needs some serious work to get it up to date for the latter versions of WAB.
GarethYoung1
Thanks Robert for having a look
