Activate tags in WebAppBuilder
629
5
07-06-2023 08:17 AM
Labels (2)
H__DanielRamos_Mendoza
Activate tags in WebAppBuilder.
I've created a layer with new FeatureLayer. Also turn on the "showLabels: true" labels. It is not shown on the map.
In which WebAppBuilder file are the tags activated?
DavidSolari
Labels are controlled by the web map's definition and are limited to whatever's supported by the "classic" map viewer, if they display there they should display in WAB. IF that doesn't work, you may have a widget that's inhibiting the labels, try making a new app from scratch to see if they appear. If all of that fails I'd take it up with support.
I am creating a layer by code. According to the documentation, it tells me that I must create the property "showLabels: true" in the object new Map().
I am looking inside the WebAppBuilder code for the new Map() object to add the property "showLabels: true"
They ask me to add the in the MAP object showLabels : true
https://developers.arcgis.com/javascript/3/jssamples/layers_label.html
I re-created a new app and the label is not showing.
Al crear asignar el valor a la geometría de puntos, se toma su tiempo de milisegundos pero se soluciona con un settimeout
