Add a multi select to the filter widget in Web AppBuilder
12371
13
01-11-2018 11:56 AM
Status: Open
XanderBakker
Esri Esteemed Contributor
Web AppBuilder for ArcGIS has some great possibilities to filter data with nested sets of filters. However, when a user would like to facilitate the selection of multiple items from the same field filled with categorical data, one could end up nesting many filters connected with an OR operator.
It would be nice to have a multi select filter type that allow a single filter configuration and that allows the selection of multiple items from the same field. For instance a field that has a domain defined for it.
Something like for instance in this jQuery example:
13 Comments
JanHavlas
Do you know when the "is any of" filter option will be implemented in Portal for ArcGIS as well (not just in ArcGIS Online)?
TonghuiMing
It has been implemented since portal 10.7 version (2018 Dec).
Ursu_Lacramioara
Hello, I am using  the WebAppBuilder version 2.14 (AGOL) and the Select Any in the Filter Expression is not working. When I Select Any and then choose Save the selection is not saved. Any ideas?
