Zoom to selected feature doesn't work
4429
06-24-2013 02:48 AM
TAMARADIEZ
We have an application developed on Siverlight. One of its tools is to zoom to a selected ward. It used to work but it stop working and I am not sure why. I have debugged the code and  I think it is failing on this part of the code:
" ESRI.ArcGIS.Client.Geometry.Envelope selectedFeatureExtent = selectedFeature.Geometry.Extent;". Please see all the code below and attached a screenshots of when I hover the selectedFeature and Geometry elements while debugging.
Could someone help me please?
T
  private void WardQueryTask_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.QueryEventArgs args)
            FeatureSet featureSet = args.FeatureSet;
            var enumGraphics = from g in args.FeatureSet
                           orderby (g.Attributes["NAME"] as string) ascending
                           select g;
                // If initial query to populate states combobox
                if ((args.UserState as string) == "initial")
                    // Just show on initial load
                    QueryComboBox.Items.Add("Zoom to Ward");
                    //foreach (Graphic graphic in args.FeatureSet.Features)
                    //    QueryComboBox.Items.Add(graphic.Attributes["NAME"].ToString());
                    foreach (ESRI.ArcGIS.Client.Graphic gn in enumGraphics)
                        QueryComboBox.Items.Add(gn.Attributes["NAME"].ToString());
                    QueryComboBox.SelectedIndex = 0;
                    return;
                // Remove the first entry if "Select..."
                if (QueryComboBox.Items[0].ToString().Contains("Zoom to Ward"))
                    QueryComboBox.Items.RemoveAt(0);
                // If an item has been selected
                GraphicsLayer graphicsLayer = Map.Layers["MyGraphicsLayer"] as GraphicsLayer;
                graphicsLayer.ClearGraphics();
                if (featureSet != null && featureSet.Features.Count > 0)
                    // Show selected feature attributes in DataGrid
                    Graphic selectedFeature = featureSet.Features[0];
                    // Hightlight selected feature
                    selectedFeature.Symbol = WardSelectSymbol;
                    graphicsLayer.Graphics.Add(selectedFeature);
                    // Zoom to selected feature (define expand percentage)
                    double expandPercentage = 30;
                    double widthExpand = selectedFeatureExtent.Width * (expandPercentage / 100);
                    double heightExpand = selectedFeatureExtent.Height * (expandPercentage / 100);
                    ESRI.ArcGIS.Client.Geometry.Envelope displayExtent = new ESRI.ArcGIS.Client.Geometry.Envelope(
                    selectedFeatureExtent.XMin - (widthExpand / 5),
                    selectedFeatureExtent.YMin - (heightExpand / 5),
                    selectedFeatureExtent.XMax + (widthExpand / 5),
                    selectedFeatureExtent.YMax + (heightExpand / 5));
                    Map.ZoomDuration = new TimeSpan(0, 0, 1);
                    Map.PanDuration = new TimeSpan(0, 0, 1);
                    Map.ZoomTo(displayExtent);
by Anonymous User
Not applicable
Original User: tamadie
Hello tamadie,
I think this post belongs in the API-section of the forums.
However, I think your problem is that you don't return geometries from your query. Have a look at the ReturnGeometry setting.
Yes, I add myQuery.ReturnGeometry = true; to the code and it fixed the issue.
I will make sure next time I post this kind of questions in the correct forum.
Many times for your help.
Kind Regards,
T
T
JohanCarlsson
Hello tamadie,
by Anonymous User
Not applicable
Hello tamadie,
Kind Regards,
T
T
