???Unable to deploy application??? using Silverlight builder,
5822
02-06-2013 10:33 AM
by Anonymous User
Not applicable
Original User: [email protected]
I tried to deploy the web application using Silverlight builder but I got the message below:
[ATTACH=CONFIG]21519[/ATTACH], [ATTACH=CONFIG]21520[/ATTACH]
What might be the issue?
Best
Jamal
by Anonymous User
Not applicable
Original User: katydalton
Hi Jamal,
That error can mean a few things including that you don't have write permissions to the the Apps folder (C:\inetpub\wwwroot\Apps) or that the name of the App already exists.
Hope that helps,
Katy
by Anonymous User
Not applicable
Hi Jamal,
Hope that helps,
Katy
JamalNUMAN
Legendary Contributor
Hi Jamal,
Hope that helps,
Katy
Thank you Katherine for the help. It worked as a charm!
I shared the Apps folder to everyone and grant full control to everyone and thus it worked
[ATTACH=CONFIG]21691[/ATTACH], [ATTACH=CONFIG]21692[/ATTACH]
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: PietaS175
This is typically a security issue on a server. Restricted permission to example the inetpub\wwwroot folder
Never a good idea to give unrestricted access to these folders
Better alternative is to deploy on a desktop/laptop and to copy application over to the server using the appropriate permissions
Alternatively, use a folder other than in wwwroot and share it in IIS
JamalNUMAN
Many thanks Pieta,
This sounds to be a better practice.
Your help is appreciated
Best
Jamal
Jamal Numan
