Silverlight Builder Configuration- adding copyright text on the webviewer
3417
04-06-2014 01:27 PM
afafabbas
Hi, I got a request from the client to add a copyright disclaimer on the Silverlight webviewer.
I used the ???Title and Links??? configuration tools to add the copyright as text. The client objection to this is the copyright text disappear behind the ???map title??? when the window is reduced in size.
Is there a way to add the copyright text on the map itself rather than adding it to the Viewer template?   I know we can do that in ArcGIS online by adding the copyright under ???credits??? when publishing the service, can we do this somehow on the Silverlight Webmap? I'm using Silverlight 5.1.20913.0 .  Thanks
BrianLeroux
If you edit the template you are using, you can put the copyright wherever you want. I do this a lot to move the map elements around and add new menu bars and such.
