Sign into a local ArcGIS Portal Install
3242
02-22-2012 10:12 AM
HeathHatcher
I'm trying to find a setting or the line that allows you to adjust the sign in for ArcGIS Portal.  We have an internal install running, and use it to direct to many of our internal services.  Has anyone found the specific line to allow a user to log into a local portal?
KatherineDalton
Hi Heath,
You can go to the Application Builder>Settings>Application Settings tab and enter information for ArcGIS Portal. See Application" rel="nofollow" target="_blank">http://help.arcgis.com/en/webapps/silverlightviewer/help... Builder settings for info.
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
HeathHatcher
Hi Katy,
Thanks for the response.  I saw that, but misunderstood what it was saying, and thought it was just referring to the basemaps. Have it set up now 🙂
Hi Heath,
You can go to the Application Builder>Settings>Application Settings tab and enter information for ArcGIS Portal. See Application Builder settings for info.
Katy
