Set SelectedLayer other than by Index or ID?
3138
07-29-2013 09:39 AM
SteveClark
MapApplication.Current.SelectedLayer = MapApplication.Current.Map.Layers[] has the ability to select by ID (which can change if layer is re-added) or by Index (which the order can change as well). How could set the SelectedLayer by URL or by something that is unique and constant?
by Anonymous User
Not applicable
Original User: PietaS175
Something like this:
string layerName = "My layer name";
if (MapApplication.Current != null && MapApplication.Current.Map != null && MapApplication.Current.Map.Layers != null)
     LayerCollection layers = MapApplication.Current.Map.Layers;
     while (layers.Any(l => MapApplication.GetLayerName(l) == layerName))
           Do what you want here ....................
SteveClark
Thank you, I will give that a try.
