Why does silverlight crash when a geoprocessingservice returns an empy feature layer?
1201
08-05-2013 03:12 AM
BertHavekes
I use Python to build geprocessing tools a query on feautures. As a result I sent back a feature layer (derived output) with
arcpy.SetParameter(2,output_layer)
This works perfect in most cases. But the problem is when you did not found where you're looking for. Then the resulting feaute layer is empty. For AGS, this is no problem: The result I get in that case is:
Geoprocessing Parameter: Gevonden_Graafbericht
Data Type: GPFeatureRecordSetLayer
Geometry Type: esriGeometryPolygon
Spatial Reference: 28992
# records: 0
The problem is that when the silverlight viewer get's back this result, the silverlight plugin crashes!!!
Is there anybody how knows the reason, or better, how to fix this?
I'm using ArcGIS Viewer for Silverlight version 3.1 and AGS 10 SP5
kind regards,
Bert Havekes
(from the Netherlands)
PietaSwanepoel2
Bert,
I assume you are using the GP tools in app builder. Not sure how grasefully the add-in will die when the inputs are not as expected.
Maybe play around with output from the python script. Try returning something like a null value (None in python) if the return is empty.
