Secure Map services in the Silverlight Viewer
2901
05-30-2012 08:50 AM
StephanieSnider
I'm creating a Silverlight web map that is restricted for internal use within our department.  The map service contains sensitive datasets that cannot be published to the public.  Is there a way to make a map service not viewable to the public yet have it accessible for the Silverlight web map?  In the past, I experimented with enabling securities for map services within ArcGIS Server, but that caused all kinds of problems in the Flex web app since many widgets do not work with the secure map service.
How well does the Silverlight Viewer work with secure map services?
Stephanie
KatherineDalton
Hi Stephanie,
You can add secured services via a Proxy Url as described  [url=http://help.arcgis.com/en/webapps/silverlightviewer/help/index.html#/Adding_secured_services/0177000...]. Note, though, that secured basemaps and geoprocessing services are not supported. Let us know if there is a specific issue you run in to with using any of the tools with secured services.
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
ZacharyHart
Honored Contributor
Are we going to see secured GP services available with the 10.1 release?
