Problem with proxy settings
3628
04-16-2013 08:38 AM
MaximPetroshenko
Hello
I tried to use Services from remote computer with credentials (login and password), which I know. I made an application using Arcgis Viewer for SL. So I try to make secured service with proxy. According to your instructions here:
http://resources.arcgis.com/en/help/silverlight-viewer/concepts/index.html#/Adding_secured_services/...
http://resources.arcgis.com/en/help/silverlight-viewer/concepts/index.html#/Configuring_a_proxy/0177...
I made proxy application in my IIS (I validated it by proxy.ashx?ping).
My proxy.config:
<serverItem url="http://myservice/arcgis/rest/services"
                matchAll="false"
                username="Myuser"
                password="Mypass"
                tokenUrl="http://myservice/arcgis/tokens"
                timeout="30" />
Then I try to coonect to http://myservice/arcgis/rest/services in Viewer SL, but i had an exception: "Unable to connect to http://myservice/arcgis/rest/services"
In fiddler:GET /proxy/proxy.ashx?http%3a%2f%2myservice%2farcgis%2frest%2finfo%3ff%3djson& HTTP/1.1 with 500 error
Could you tell me the reason of this? Or make more detailed instruction please?
Best regards
Max
PaulDioguardo
I'm having a similar issue. I have configured  the silverlight proxy page (for 3.3) per ESRI's instructions and confirmed with the ping url, but when adding a layer with the "use proxy" checked I get an "Unable to connect to https:// .... " error. I can connect via browser to the secured map services with the username/password, and can connect and login with secured services in the Silverlight Viewer authoring tool, but cannot get the proxy page working.
Can an ESRi staff member address these questions?
Paul
