New Silverlight Viewer - Expected Release Date?
3677
16
09-11-2012 05:22 AM
IanPeebles
I have heard from a colleague that a new Silverlight Viewer is expected to be released very soon.  Anyone have and idea on the expected released and what type of additional functionality it will include?  Also, how long does ESRI plan to support the Silverlight Viewer?
DerekLaw
Esri Esteemed Contributor
Hi Ian,
We're targeting the next release for late Sept/early Oct timeframe (so very soon!)
It will include the following as part of its core functionality:
- bookmarks tool
- measure tool
- support for custom locators
- print tool (supports the new 10.1 Printingtools GP service)
It will be built and compiled on the ArcGIS v3.0 API for Silverlight release.
We're planning on supporting the ArcGIS Viewer for Silverlight for the foreseeable future. It (along with the ArcGIS Viewer for Flex) is the out-of-the-box, configurable web mapping application builder for ArcGIS for Server moving forward.
Hope this helps,
ZacharyHart
Honored Contributor
Hi Ian,
- bookmarks tool
- measure tool
Hope this helps,
Will 3.0 have an identity manager built-in to handle secured arcgis server services?
DerekLaw
Hi Zachary,
The current release of the ArcGIS Viewer for Silverlight already supports secured services from ArcGIS for Server.
FYI, Adding secured services
Is this what you're asking?
Hope this helps,
ZacharyHart
Honored Contributor
Hi Zachary,
Hope this helps,
Nope...I'm talking about exposing a secured service where the client is requested to provide credentials...similar to how the Flex viewer works....
the only way to do this in SL is to embed a token in a proxy page...thus anyone with your web applications URL can see your services...the only way to secure that web application is at the web server tier. Setting that up for the average GIS person isn't exactly easy...sure its easier if you maintain your user credential store within windows/web server, but if your credential store is configured to use the AGS's built-in security you need to design a web-facing page which can access those credentials back to AGS....which sounds very round-robin to me. Additionally, the only article that i've seen from ESRI on how to set this up basically stores the user credentials within the login.aspx.
Why can't the silverlight viewer just prompt for credentials against secured map services using the identity manager like Flex does? what am I missing?
DerekLaw
Hi Zachary,
... I'm talking about exposing a secured service where the client is requested to provide credentials...similar to how the Flex viewer works ... Why can't the silverlight viewer just prompt for credentials against secured map services using the identity manager like Flex does?
We haven't implemented the ArcGIS API for Silverlight�??s identity manager into the Viewer yet. This is on the product roadmap, but is not part of the next release.
Hope this helps,
ZacharyHart
Honored Contributor
Hi Zachary,
Hope this helps,
Thanks, that does answer my question.
KirkKuykendall
Any updates on the expected release date?
Thanks, Kirk
DerekLaw
Hi Kirk,
The ArcGIS Viewer for Silverlight v3.0 release should be in the next couple of weeks.
Hope this helps,
TomFlahive
Hi Derek,
Like Zachary, the feature I was most hoping to see in the new release was an improvement in the way the Silverlight Viewer accesses secured services.  Setting up proxy pages is a pain and I've spent quite a bit of time with the ESRI help desk getting that to work (and am still having problems).  The Flex demos at the User Conference made accessing such secured services seem very easy.  I'm hoping the Silverlight Viewer team will consider moving that up the priority list to make it in the next Silverlight Viewer release.
Tom
