need to add measure tool
3722
6
01-24-2012 10:27 AM
ErnejunCorvera
Hi. I have a Map Viewer for Silverlight running and functioning well. What i need is to add a measure tool so that the user could be able to measure distances on the map. I am not a programmer and i am new to this silverlight application. What i have to do?...any help is much appreciated. Thanks.:)
DerekLaw
Esri Esteemed Contributor
Hi Ernejun,
We are working on an "add-in" sample measure tool which should be available sometime mid-late February.
Hope this helps,
RyanKoehnen
You can do it through an addin, but you would need to do some programming 😉 Here's an example...
****Measure tool command class***
    public class MeasureActionTool : ICommand
        #region ICommand members
        public void Execute(object parameter)
            SolidColorBrush b = new SolidColorBrush();
            b.Color = Colors.Orange;
            SimpleLineSymbol ls = new SimpleLineSymbol();
            ls.Color = b;
            ls.Width = 2;
            ViewerMeasureAction m = new ViewerMeasureAction()
                LineSymbol = ls,
                MeasureMode = MeasureAction.Mode.Polyline,
                DisplayTotals = true,
                DistanceUnit = DistanceUnit.Feet,
            m.Attach(MapApplication.Current.Map);
            m.Execute();
        public bool CanExecute(object parameter)
            // Return true so that the command can always be executed
            return true;
        public event EventHandler CanExecuteChanged;
        #endregion
***Wrapper class for the Silverlight measure tool***
    public class ViewerMeasureAction : MeasureAction
        public void Execute()
            Invoke(null);
ErnejunCorvera
Glad to hear that Mr. Law..
Thanks also mr. koeh0017..i'll try to this myself and hope i can make it..thanks for the code.
JohnGravois
Our development team has released a production quality, ready-to-use Measure Add-in for the Silverlight Viewer.
Measure Tool
http://www.arcgis.com/home/item.html?id=7530abad98bd471da53a2d1716928c40
RichZwaap
This has just been made available here.  This is production quality, ready-to-use tool with full source code.
TannerKneese
I received the below error after uploading the xap file... help?
