When you start to roll out localizations for the Viewer, can a single Viewer switch between multiple languages? ... Will there be a supported workflow for switching languages within the Viewer?
What is the role of the .xml configuration files in the Culture subfolders?
Finally, how would multiple localizations effect Add-In tools? Would my Add-In assembly need its own localization logic and language resource files?
Any dates on release for the localization packs, particularily French?
