Issues with 2.4 Extensibility Kit Installation
621
01-19-2012 07:26 AM
GerardoGarza
I had a couple issues with the installation of the latest Extensibility Kit which I downloaded last night after the minor update.
I am using 64-bit Windows 7 with VS2010 installed to a non-default location
  1. ESRI Viewer Template -
  2. The Template was incorrectly installed in the default location of VS2010,
    C:\Program Files (x86)\Microsoft Visual Studio 10.0\Common7\IDE\ProjectTemplates\CSharp\Silverlight\ESRI Viewer.
    This was puzzling because I had all the dependencies installed, the beta2 Extensibility Kit had installed correctly, and the Map Application Templates that come with the 2.4 API were also loaded.
    After looking at the setup log in the temp directory, I had to manually move the template to my non-default installation of VS on the D-drive.  Then I had to follow the steps in this Microsoft page to load the template.
  3. Test Viewer Output Path -
  4.    Once I loaded the template and created a project, I noticed that the Output path of the test viewer was pointed to ..\..\Bin\ instead of Bin\.  This was minor but inconsistent with the 2.2 Extensibility Template.
