How to take the advantage of the add-ins of ArcGIS in the Viewer Silverlight?
1906
01-04-2013 12:08 PM
JamalNUMAN
Legendary Contributor
I got a very powerful add-in (from very brilliant instructor) that searches any layer based on up to three fields with a functions to zoom to the found values.
[ATTACH=CONFIG]20463[/ATTACH]
How such tool can be plugged in the Silverlight?
Thank you
Best
Jamal
Jamal Numan
AlexeyTereshenkov
The logic behind ArcGIS Viewer for Silverlight Add-in and ArcGIS for Desktop Add-in is quite different. There is no way you could use the add-in from Desktop in Silverlight Viewer directly. Neither can you "recompile" the add-in to match Silverlight standards.
You will need to write an Silverlight Viewer add-in from scratch (or by using samples). Naturally you could take the idea behind Desktop add-in (written in C# or VB, for instance) and then use it as a reference when writing Silvelight add-in using ArcGIS API for Silverlight.
AlexeyTereshenkov
JamalNUMAN
Many thanks for the answer Alexey
Never be easy for non-developers as well!
Best
Jamal
Jamal Numan
