Failed to access IIS metabase
4848
9
02-01-2012 11:07 AM
MattBrodersen
Hello,
I installed ArcGIS Viewer for Silverlight 1.0, however when I go to run the program I run into the following error:
Server Error in '/Builder' Application.
Failed to access IIS metabase.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Web.Hosting.HostingEnvironmentException: Failed to access IIS metabase.
The process account used to run ASP.NET must have read access to the IIS metabase (e.g. IIS://servername/W3SVC). For information on modifying metabase permissions, please see http://support.microsoft.com/?kbid=267904.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.272
Has anyone else ran into this issue and if so, how did you resolve it?
Thanks!
MattBrodersen
My website is not running.  Nothing displays in the browser (when navigated to http://<computer name>/Builder/default.aspx) except for the error message that I posted at the beginning of the thread.  I am unfamiliar with setting the permissions on the  files you mentioned above, would it be possible for you to further explain how to go about doing this?
Thanks!
wilburESRI was correct.  After doing research elsewhere it appears that this error occurs when IIS Server is installed after installing the .NET framework.  What I had to do was open up Window's command prompt and then run paste:
C:\Windows\Microsoft.NET\Framework\v4.0.30319\aspnet_regiis.exe -i
and then hit enter.  After a few seconds of re-installing .NET framework my problem was fixed.  You just need to modify the string above with the version of .NET that you are running.  In my case,  v4.0.30319.
Hope this helps
DerekLaw
Esri Esteemed Contributor
Hi Matt,
What OS are you running?
Are you sure your machine meets all the system requirements?
Did the Silverlight Viewer install without issues?
FYI, ArcGIS Viewer for Silverlight system requirements.
Hope this helps,
MattBrodersen
Hi Matt,
Hope this helps,
Hello,
I am running Windows XP Professional 32-bit.
My machine does meet all the systems requirements.
I was able to install the Silverlight view without any issues, I followed the instructions on the same page that you provided a link to above.  However, I get the error I posted above when trying run the application.
Thanks for your reply!
-Matt
HeatherRyan
I also get this error message when trying to run the application.
My machine meets all of the requirements and I am running XP 32-bit.
Can you provide more guidance as to how to deal with this error?
Thank you.
WilburHughes
Is you Web site running? Does the Builder web application show as started and listed in IIS?  Does any part of the Builder web application display?  Does the page display if you type url http://<computer name>/Builder/default.aspx in your browser? Is there any more details you can provide?
Try setting the permission on the Builder web application.
C:\Windows\Microsoft.NET\Framework\v4.0.30319\aspnet_regiis.exe -ga <Computer Name>\ASPNET
MattBrodersen
Thanks!
MattBrodersen
Thanks!
Hope this helps
noamrozenfeld
So simple, and wasted so much time with this...
Thanks alot!
Solved my issue
TarigAhmed1
Thanks ...this solved my problem. ..
ThirukkumaranG
It solved my problem. Thank u very much.
