Cannot access ServiceReferences.ClientConfig
1267
03-01-2012 11:32 AM
Swani_Jesus_Captonsiluvairajan
I am building an Add-in for my silverlight viewer.  My addin references a regular WCF service.  The service works file if I access it in code by using
System.ServiceModel.BasicHttpBinding binding = new System.ServiceModel.BasicHttpBinding();
CIMSServiceClient cimsSvcClient = new CIMSServiceClient(binding, new System.ServiceModel.EndpointAddress("http://localhost:64128/Services/CIMSService.svc"));
but if I use the end point name as in
CIMSServiceClient cimsSvcClient= new CIMSServiceClient("BasicHttpBinding_ICIMSService");
Here is my ServiceReferences.ClientConfig file contents tha tis in the root of the AddIns project "CIMSViewer.AddIns"
<configuration>
    <system.serviceModel>
        <bindings>
            <basicHttpBinding>
                <binding name="BasicHttpBinding_ICIMSService" maxBufferSize="2147483647"
                    maxReceivedMessageSize="2147483647">
                    <security mode="None" />
                </binding>
            </basicHttpBinding>
        </bindings>
        <client>
            <endpoint address="http://localhost:64128/Services/CIMSService.svc"
                binding="basicHttpBinding" bindingConfiguration="BasicHttpBinding_ICIMSService"
                contract="CIMSServiceReference.ICIMSService" name="BasicHttpBinding_ICIMSService" />
        </client>
    </system.serviceModel>
</configuration>
It completely fails!  No idea why and there is no error message. [Can't step through code - no breaks point won't be hit - no symbols are loaded ofr this document issue - another nightmare!]
My question is, in the ESRI Silverlight Viewer framework, do we have to place the ServiceReferences.ClientConfig in a particular location?   or do I have to do anything special to read the end point information/
*******EDIT********
Got the break points to work - use IE instead of default chrome !
The error is basiclaly cannot find ServiceReferences.ClientConfig in the Viewer.xap file.  How does this Viewer.xap get generated from the layout.xap and addins.xap files?  How do I add my ServiceReferences.ClientConfig to this xap file?
Thanks for your help,
capton.
DerekLaw
Esri Esteemed Contributor
Hi Capton,
... How does this Viewer.xap get generated from the layout.xap and addins.xap files?  How do I add my ServiceReferences.ClientConfig to this xap file?
FYI,
Just to close the loop on this thread, Katy - a PE on the Silverlight Viewer Dev team, responded to your similar question in another thread:
How does Viewer.xap File get generated?
Hope this helps,
