Basemap Transparency/Opacity
5887
05-27-2012 01:09 AM
AndrewSheekey
Hi All,
Not sure if I've missed it in the viewer, but there doesn't seem to be a way of setting the transparency of the basemaps like there is in the Flex Viewer.  Is this possible by adding code to the map.xml or is it much more complicated?
A.
KatherineDalton
Hi Andrew,
You should be able to set the basemap transparency on the Configure Layers panel. The only thing you cannot do is completely remove the basemap layer.
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
KatherineDalton
Hi Andrew,
Katy
AndrewSheekey
Thank you!  I didn't realise the configuration settings remained if the configuration button was disabled.
Thanks for your help.
