Robert,
Thanks! We're excited with the changes in 2.5.1.6, and with what we can now make the <zoomscale> tag do.
Here's what we're seeing on our end, however, and I want to bounce something by you...press our luck, so to speak.
The zoom function when selecting a record from the returned results now seems to follow the zoomscale percentage to a tee, as does the "Zoom To" button on the mouse-over call-out window for the selected record. The "Zoom" button atop the results window, however, still seems to revert back to a default zoomscale based on returned geometry.
This would actually not be a big deal if it were slightly altered so that selecting a record from the results window and hitting the "Zoom" button observed the zoomscale zoompercent setting while hitting the "Zoom To" button zoomed in to the returned geometry. From an intuitive work-flow perspective I believe having the interactive results and the "Zoom" button returning the zoompercentage makes sense, working together so to speak. Then if one wanted to zero right in on a selected feature they could use the "Zoom To" button on the call-out window associated with it.
Like you, we have to consider the "Mee-Maw and Pee-Paw Factor" when putting these things together, in a sense pandering to a lower common denominator of public tech-sophistication than we all might like. So if there's a way we can make that switch in our configuration, let me know...although I suspect it's probably something on your end (thus my "press out luck" comment earlier).
Whatever happens, thanks so much for developing this wonderful tool, but especially for being so receptive and helpful!!!
Eric
