Work with map coordinates
1751
03-27-2012 11:46 PM
RadekMatouch
I need this function and I don't know if any widget allows it: Click to the map, save coordinates (X),(Y) and then automatically use this coordinates in web address (for example open browser whit this address http://nahlizenidokn.cuzk.cz/MapaIdentifikace.aspx?&x=(X)&y=(Y)
RadekMatouch
Radek,
Working with coordinates (copy, convert, project ...).
You can specify either an extent or a center point with a map scale or specific zoom level.
Yes, thank you. I know this widget (and I use it)..But I need little bit different function - automatically open web browser with specific address (including X,Y coordinates)
RobertScheitlin__GISP
Radek,
    No there is not a widget already out there that does specifically what you need. You will have to develop it yourself. What you are wanting is not hard.
RadekMatouch
Radek,
Thank you..Yes, it seems to be easy..But I'm not programmer, I can only use and configurate some widget 🙂 That's why I'm looking for finished solution.
But I think I have to learn basics of widgets programming..
