weather undergound widget
1438
01-24-2012 04:35 AM
philippschnetzer
Is it possible to hide the icons from the weather underground widget when zoomed out beyond a certain scale?  I am using this widget completely in the background and not giving the user any ability to control it....but I find when zoomed out too far the icons clutter the map....
I've made an attempt to do this in the code but do not feel like posting my pathetic erroneous attempt...
Thanks!
RobertScheitlin__GISP
Phillip,
   All you need to do is add this right after map.addLayer(graphicsLayer) in the init function and adjust the 40000 to your preferred scale:
                map.addEventListener(ZoomEvent.ZOOM_END, checkScale);                 if(map.scale > 40000)                     graphicsLayer.visible = false;
Add this import:
import com.esri.ags.events.ZoomEvent;
And this new function:
private function checkScale(evt:Event):void             {                 if(map.scale > 40000){                     graphicsLayer.visible = false;                 }else{                     graphicsLayer.visible = true;                 }             }
Phillip,
Add this import:
philippschnetzer
Perfect!  Thanks, Robert!
