visibility of "enter address" prompt
758
06-05-2013 01:38 AM
JamesEdge
I am using source code for Flexviewer 3.2 - How can I adjust the visibility level of the "enter address" prompt within the headercontoller?
RobertScheitlin__GISP
James,
   Glad to help.
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow these steps as shown in the below graphic:
GISDev1
What do you mean by visibility level? You want to make a red box around it or what?
James,
   You would need to modify the GeoCoderSkins promptDisplay.  http://resources.arcgis.com/en/help/flex-api/apiref/com/esri/ags/skins/GeocoderSkin.html
JamesEdge
I was able to copy the skin from the API into my viewer and set link in default.css to use my skin. I removed promptDisplay from the colorization exclusions so that the "enter address" is now fully visible. Many thanks Robert.
James,
   Glad to help.
