Viewer 3.2 Geoprocessing widget error
3856
7
03-25-2013 08:53 AM
DanielSmith
Hello,
Today i downloaded the new ArcGIS Viewer for Flex v3.2 from gitHub. The import and adding the swc as usual went fine but i got an error in the Georpocessing widget.
Specifically it was located in rendereres >input>GPInputDataFileParamItemRenderer.mxml>Line 132 (in the fileRef_uploadCompleteDataHandler() function).
The error says 'Access to undefined property JSON'.
Importing com.esri.ags.utils.JSONUtil and modifying the call on line 132 to:
handleResponseObject(JSONUtil.decode(event.data))
handleResponseObject(JSON.parse(event.data));
resolved the error.
I am not using the geoprocessing widget right now, but will be soon so wanted to make sure this was gonna fly once i do use it.
-daniel
GISDev1
GISDev1
Hello,
resolved the error.
-daniel
I see that as well, but I don't get an error upon compiling. Which Flex SDK are you using?
DanielSmith
using default of 4.5.1
GISDev1
I think you need to use SDK 4.6 for Flex Viewer 3.2:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Flex_development/01m30000002000...
DanielSmith
ok, thanks. i have downloaded the SDK from http://www.adobe.com/devnet/flex/flex-sdk-download.html , extracted, and imported through Window>Preferences>Flash Builder > Installed Flex SDKs.
I then changed the line of code back to what it was previously, referenced the 4.6 SDK under the Flex SDK version in project properties and all errors are gone.
Many thanks for the quick help.
GISDev1
That's good. If you click that green checkmark over on the right side of the post, it will mark the thread as Answered.
DanielSmith
cool. also gave a +1 as you answered so quickly and correctly. many thanks again.
LipLi
Thanks a lot ! I was encountered this problems in morning ,luckly finding this log .
