Using Related Tables in Flex Viewer
7986
23
05-31-2012 12:09 PM
AmySadler
Hello! I am fairly new to using ArcGIS for Flex and am trying to set up a viewer for my organization. I am wanting to use the Query widget to allow users to search for information on a table. The table is related back to a layer and I can see it on my server, but when I go to use the data in the widget, I get error #1009. Is it possible to use a table in the query widget or does it have to be a feature class?
On a related note, can you use information in a related table to populate a "pop-up" for a feature?
Thanks very much for your help!
Amy S.
RobertScheitlin__GISP
Joseph,
   I don't think that is even possible in ArcMap... No this is not a capability of the eSearch and is unlike to be added based on the complexity of the task. Think about what would have to happen if there was a one to many relate of one record with thousands of related records to just that one result....
JosephAccardi
No problem Robert. The way you do it in ArcMap is if your feature class and related table are saved in a geodatabase you can perform a 1:M join. A join within a geodatabase will populate all matching records (not just the first matching record). From there you can export out the feature class to append the related attributes. (http://resources.arcgis.com/en/help/main/10.1/index.html#//005s0000002n000000).
Joe
Joe,
  OK, that make sense. Joins and Relates are two different animals.
MichaelVolz
Esteemed Contributor
Robert:
Can you use a mapservice with a datasource that uses a Query Layer to a SQL Server database table with your eSearch widget? I would like to be able to access related records that have been enabled from the Query Layer?
If this is possible, what version of your widget and/or the FlexViewer software would be needed?
Michael,
  I can not say that I have tested Query Layers in the eSearch widget. Give it a go and let me know the results.
MichaelVolz
Robert:
I first tried to make configuration changes that would allow me to with related record information in the datagrid for a Query Layer, but that did not return any records.
I then made configuration changes just to use a standard ArcMap relate and that also did not return any records.
Does the related records mean you can access records from a relate created in ArcMap?  Or does it mean something else?
Can you explain how the configuration file should be modified so the related records get populated?
Michael,
   The relate has to be accessible for the REST Service directory. So when you publish a mxd that has a relate in ArcMap or a real relationship class in a geodatabase that relate gets exposed in the REST Service directory. There are examples of relates in the eSearchWidget.xml that come with the eSearch download.
MichaelVolz
How would I be able to tell from the REST page that the relate is accessible from ArcGIS Server?
Can you pinpoint where in the documentation I would find more information about accessing related records?
Michael,
   You can see if a relate is available when you go to the REST Service directory for your map service layer and scroll down to the bottom. It would look something like this:
Relationships:
    calhoun.COUNTY.A_Bridge (0) -- Related To: ABIMS Bridges (0)
    calhoun.COUNTY.ADT (1) -- Related To: Average Daily Traffic (1)
    calhoun.COUNTY.Rail_Cross (2) -- Related To: Railroad Crossings (2)
    calhoun.COUNTY.Signs (3) -- Related To: Road Signs (3)
    calhoun.COUNTY.Guardrail (4) -- Related To: Guardrails (4)
Supported Interfaces:   REST
Supported Operations:   Query   Query Related Records
As far as documentation for using relates in my widget that would be covered in the Enhanced Search Widget XML Configuration.pdf page 5.
MichaelVolz
Robert:
Thank you for the additional information, but the related records portion of the datagrid is still not getting populated.
When I first accessed the REST services the relationship did not show up even though a relationship existed on the layer.  The layer was created from a lyr file and when the lyr file is brought into an mxd, the related tables do not automatically appear.  I needed to open the table view and then use the Related Tables button on the toolbar to bring in the related tables.  I then had to stop and start the mapservice and refresh the REST cache.
Do I need to add table information for the related table in the config file below the layers definition area?  I did not add table information below the layers area as I thought the fields all="true" would populate the related record portion of the datagrid.
