Pop-up for (field format)
2867
05-11-2014 11:57 PM
by Anonymous User
Not applicable
Original User: GISCCED
Dear my friends,
Actually I was working with Precision , but it is not working , i need to appear two number after dot !
example :
number 2345.8975475
request : 2345.89
can you give me advise about that  ???
in the attached , two image about this thread
thanks you
Regards,
Mohammed
RobertScheitlin__GISP
Mohammed,
   The dialog that you are showing is for configuring the POPUP and does not control the format of that field for the Attribute Table widget that you are showing in your first picture. You will notice in the App Builder configuration for the Attribute Table (in the Layout tab), there is no option to configure the fields format. This option is just not available for the Attribute Table widget.
