Using BING base maps and geocoder
1212
01-17-2012 03:43 PM
HeatherKelley
Can a person use Bing maps and Geocoder in the compliled Flex Viewer or do I need to make these edits in the full version of the software?
RobertScheitlin__GISP
Heather,
   First thing is make sure you post Flex Viewer and/or widget questions to the Flex Viewer forum:
http://forums.arcgis.com/forums/111-ArcGIS-Viewer-for-Flex
Absolutely you can use Bing Maps and geocoder in the compiled Flex Viewer.
Look at this:
<bing>
If using Bing Maps for maps or geocoding, you need to provide your  key, which has the following attribute:
  • key???Your bing key. Required.
The following is a subset of the config.xml file and its general properties:
<configuration>     <title>ArcGIS Viewer for Flex</title>     <subtitle>... using ArcGIS</subtitle>     <logo>assets/images/logo.png</logo>     <style>         <colors>0xFFFFFF,0x333333,0x101010,0x000000,0xFFD700</colors>         <alpha>0.8</alpha>     </style>     <bing key="your-bing-key"/>     ... </configuration>
from this page:
http://help.arcgis.com/en/webapps/flexviewer/help/index.html#/Main_configuration_file/01m30000001800...
Also look at this page for configuring Bing BaseMap layers:
http://help.arcgis.com/en/webapps/flexviewer/help/index.html#/Layer_tag/01m30000000p000000/
For the locator widget and configuring it to use Bing look at this link:
http://help.arcgis.com/en/webapps/flexviewer/help/index.html#/Locate_widget_tags/01m30000000r000000/
Don't forget to click the top arrow (promote) and to click the Mark as answer check as shown below:
Heather,
Look at this:
<bing>
from this page:
HeatherKelley
Thank you Robert!  I appreciate the help.
