Identify Widget 2.2.2  Fields are not being displayed
5019
13
03-09-2011 10:27 AM
MatthewStarr
Identify Widget 2.2.2 for Flex 2.2  using AGS9.3.1
I am having a problem displaying any field in the identify pop up that i have defined in the XML.  other feature such as "parcels" that are visible but not defined specifically ARE displayed.
http://71.176.110.94/survey/index.html
Which leads me to believe user error is involved here.  As you can see I am trying to avoid having the whole  URL in the link field in the GDB however I cannot get any field to display.  The Name does display correctly for the feature layer clicked so i believe it is 'seeing' the layer, just not the fields.  I have tried converting the data to shapefile, as is the case with NGS and Parcels, but GRS remains a file GDB.
any thoughts would be welcome.  thanks in advance Robert.
Matt
below are my markup files
IdentifyWidget.xml
<?xml version="1.0" ?>
    // Version 2.2.2 - Feb. 18, 2010
<configuration>
 <identifylayeroption>visible</identifylayeroption>
 <identifytolerance>5</identifytolerance>
 <defaultzoomscale>5000</defaultzoomscale>
 <keepidentifyactive>true</keepidentifyactive>
 <returngeometryforzoom>true</returngeometryforzoom>
 <labels>
  <zoom2message>Click to Zoom to Point</zoom2message>
  <identifylabel>Identify</identifylabel>
  <resultslabel>Results</resultslabel>
  <descriptionlabel>Use the identify tool to identify features on the map:</descriptionlabel>
  <pointlabel>Identify</pointlabel>
  <clearlabel>Clear</clearlabel>
  <loadinglabel>Loading...</loadinglabel>
 </labels>
 <useproxy>
  <proxylayer>
   <!--<name>Imagery</name>-->
  </proxylayer>
 </useproxy>
 <layers onlythese="false">
  <layer>
   <name>GRS</name>
   <fields>XCOORD,ID</fields>
   <linkfield>ID</linkfield>
   <linkprefix>http://71.176.110.94/survey/TieSketch/GRS</linkprefix>
   <linksuffix>.pdf</linksuffix>
   <iconfield></iconfield>
   <iconprefix></iconprefix>
   <iconsuffix></iconsuffix>
   <zoomscale>15000</zoomscale>
   <forcescale>true</forcescale>
  </layer>
  <layer>
   <name>NGS</name>
   <fields>PID,DATA_SRCE</fields>
   <linkfield>DATA_SRCE</linkfield>
   <linkprefix></linkprefix>
   <linksuffix></linksuffix>
  </layer>
 </layers>
 <info>widgets/InfoTemplates/InfoPopupWidget.swf</info>
</configuration>
Config.XML
// Copyright (c) 2010 ESRI
// All rights reserved under the copyright laws of the United States.
// You may freely redistribute and use this software, with or
// without modification, provided you include the original copyright
// and use restrictions.  See use restrictions in the file:
// <install location>/License.txt
// Read more about ArcGIS Viewer for Flex 2.2 - http://links.esri.com/flexviewer
<configuration>
    <title>Cayuga County Survey Control</title>
    <subtitle></subtitle>
    <logo>assets/images/bronzeseal.png</logo>
    <style>
  <colors>0xCCCCCC,0x777777,0x555555,0x333333,0xCCCCCC</colors>
  <alpha>0.8</alpha>
    </style>
 <bing key="AuZ1Kmk2LSfUH7S3BeZGe_7n99naRNMxTN-4kQIWz6ZZkPQklow-ib102hanVZ2-" />
    <!-- UI elements -->
    <widget left="10"  top="50"    config="widgets/Navigation/NavigationWidget.xml" url="widgets/Navigation/NavigationWidget.swf"/>
    <widget right="-2" bottom="-2" config="widgets/OverviewMap/OverviewMapWidget.xml" url="widgets/OverviewMap/OverviewMapWidget.swf"/>
    <widget right="20" top="55"    config="widgets/MapSwitcher/MapSwitcherWidget.xml" url="widgets/MapSwitcher/MapSwitcherWidget.swf"/>
    <widget left="0"   top="0"     config="widgets/HeaderController/HeaderControllerWidget.xml" url="widgets/HeaderController/HeaderControllerWidget.swf"/>
    <map initialextent="-8529900 5298700 -8517300 5305760" top="40">
        <basemaps>
   <layer label="Roads" type="bing" visible="true" alpha="1" style="road" culture="en-US"  />
            <layer label="Bing" type="bing" visible="false" alpha="1" style="aerialWithLabels" culture="en-US" />
        </basemaps>
        <operationallayers>
   <layer label="NGS" type="feature" visible="true" alpha="1"
     info="widgets/InfoTemplates/SimpleInfoWinWidget.swf"
                   infoconfig="widgets/InfoTemplates/IWT_NGS.xml"
                   url="http://71.176.110.94/ArcGIS/rest/services/survey/MapServer/2"/>
   <layer label="GRS" type="feature" visible="true" alpha="1"
                   infoconfig="widgets/InfoTemplates/IWT_GRS.xml"
                   url="http://71.176.110.94/ArcGIS/rest/services/survey/MapServer/3"/>
   <layer label="DEC" type="feature" visible="true" alpha="1"
                   infoconfig="widgets/InfoTemplates/IWT_DEC.xml"
                   url="http://71.176.110.94/ArcGIS/rest/services/survey/MapServer/4"/>
   <layer label="Parcels" type="feature" visible="true" alpha="1"
     <info="widgets/InfoTemplates/SimpleInfoWinWidget.swf"
                   infoconfig="widgets/InfoTemplates/IWT_ComercialProperties.xml"
     url="http://71.176.110.94/ArcGIS/rest/services/survey/MapServer/6"/>
   <!--<layer label="Survey Control" type="dynamic" visible="true" visiblelayers="0,1,5,6"
     url="http://71.176.110.94/ArcGIS/rest/services/Survey/MapServer"/>-->
        </operationallayers>
    </map>
    <!-- widgets organized into widget containers that manage close/open etc -->
    <!-- supported layout property options: horizontal(default)|float|vertical|fix-->
 <widget preload="open"
  config="widgets/Splash/SplashWidget.xml"
  url="widgets/Splash/SplashWidget.swf"/>
 <widgetcontainer layout="float">
      <widget label="Bookmarks"         left="430" top="90"
                icon="assets/images/i_bookmark.png"
                config="widgets/Bookmark/BookmarkWidget.xml"
                url="widgets/Bookmark/BookmarkWidget.swf"/>
        <widget label="Find an address"   left="590" top="280"
                icon="assets/images/i_target.png"
                config="widgets/Locate/LocateWidget_US.xml"
                url="widgets/Locate/LocateWidget.swf"/>
        <!--<widget label="Available Commercial Facilities" left="100" top="90" preload="open"
                icon="assets/images/i_flag.png"
                config="widgets/Query/QueryWidget_CEDA_CommercialProperties.xml"
                url="widgets/Query/QueryWidget.swf"/>-->
        <widget label="Draw and Measure" left="60" top="400"
                icon="assets/images/i_draw2.png"
                config="widgets/Draw/DrawWidget.xml"
                url="widgets/Draw/DrawWidget.swf"/>
        <widget label="Print" left="390" top="400"
                icon="assets/images/i_print.png"
                config="widgets/Print/PrintWidget.xml"
                url="widgets/Print/PrintWidget.swf"/>
        <!--<widget label="Google Street View" left="430" top="90"
    icon="assets/images/i_Streetview.png"
    config="widgets/Streetview/StreetviewWidget.xml"
    url="widgets/Streetview/StreetviewWidget.swf"/>-->
  <widget label="Identify" left="60" top="400"
                icon="assets/images/i_info.png"
                config="widgets/Identify/IdentifyWidget.xml"
                url="widgets/Identify/IdentifyWidget.swf"/>
  <!--<widget label="Search" left="60" top="400"
                icon="assets/images/i_searchgraphical.png"
                config="widgets/Search/SearchWidget_ComProp.xml"
                url="widgets/Search/SearchWidget.swf"/>-->
        <!--<widget label="eSearch" left="60" top="400"
                config="widgets/eSearch/SearchWidget.xml"
                url="widgets/eSearch/SearchWidget.swf"/>-->
    </widgetcontainer>
</configuration>
RobertScheitlin__GISP
Matt,
I see an syntax error in your main config.xml
MatthewStarr
Robert again thank you.  what XML editor do you use/recommend? I should not have missed that.
Matt,
   I just use notepad for the editing and use internet explorer to validate the xml because IE is really good at fussing about syntax.
MatthewStarr
That doesn't seem to effect the identify functionality.. it is for the info popup. I will comb over my other mark up for similar syntax errors
JonFisher
I have to put in a HUGE recommendation for Notepad++. Not only does it color different elements for you (e.g. tags in blue, attributes in red, attribute values in purple, comments in green) which makes syntax errors much easier to spot, it just has an enormous library of bonus functionality (comparing two documents, tracking changes, search and replace across multiple files in a common directory,etc.)
You can get it from http://notepad-plus-plus.org/
I really can't recommend it highly enough. I was a notepad man for years, but this software changed my life. Plus, I really like that they accept donations but 100% of the money just goes to charity to inspire them. And no, I am in no way involved with the development or the team 😉
Matt,
   Can you screen shot what you are seeing in the identify widgets results and info window?
MatthewStarr
Thanks for looking at this again Robert.  I attached a screen shot. and this is the link
and layer
http://71.176.110.94/ArcGIS/rest/services/survey/MapServer/0
The Code has changes since my original post:
<configuration>
 <identifylayeroption>top</identifylayeroption>
 <labels>
 </labels>
 <useproxy>
  <proxylayer>
  </proxylayer>
 </useproxy>
  <layer>
   <name>CountyControlPoints</name>
   <fields>Reference,Northing,Easting,Elevation,Link,CNTRL_TWN</fields>
   <linkfield>link</linkfield>
  </layer>
  <layer>
   <name>xNGS</name>
  </layer>
 </layers>
 <!--<info>widgets/InfoTemplates/SimpleInfoWinWidget.swf</info>-->
</configuration>
CONFIG
<configuration>
    <style>
  <alpha>0.8</alpha>
    </style>
        <basemaps>
        </basemaps>
        <operationallayers>
   <layer label="Parcels" type="dynamic" visible="true" alpha="1"
     url="http://71.176.110.94/ArcGIS/rest/services/parcels/MapServer"/>
   <!--<layer label="NGS" type="feature" visible="false" alpha="1"
     url="http://71.176.110.94/ArcGIS/rest/services/survey/MapServer/1"/>
   <layer label="GRS" type="feature" visible="false" alpha="1"
   <layer label="DEC" type="feature" visible="false" alpha="1"
     url="http://71.176.110.94/ArcGIS/rest/services/survey/MapServer/3"/>-->
   <layer label="CountyControlPoints" type="feature" visible="true" alpha="1"
     infoconfig="widgets/InfoTemplates/IWT_AllPoints.xml"
     url="http://71.176.110.94/ArcGIS/rest/services/survey/MapServer/0"/>
   <!--<layer label="Zones" type="dynamic" visible="true" alpha="1"
     url="http://71.176.110.94/ArcGIS/rest/services/survey/MapServer/4"/>-->
     <!--info="widgets/InfoTemplates/SimpleInfoWinWidget.swf"
     infoconfig="widgets/InfoTemplates/IWT_ComercialProperties.xml"-->
    </map>
        <!--<widget label="DEC Survey Control" left="100" top="395" preload="open"
                icon="assets/images/yellowdot.png"
                config="widgets/Query/QueryWidget_DEC.xml"
  <widget label="NOAA Survey Control" left="100" top="700" preload="open"
                icon="assets/images/w_close_red.png"
                config="widgets/Query/QueryWidget_NGS.xml"
  <!--<widget label="Cayuga County Survey Control" left="100" top="90"
                config="widgets/Query/QueryWidget_GRS.xml"
  <widget label="Identify" left="60" top="90" preload="open"
  <widget label="Search" left="60" top="495" preload="open"
                config="widgets/Search/SearchWidget_CountyControl.xml"
    </widgetcontainer>
</configuration>
Matt,
    When I remove the info attribute from the feature layers I can get your services to work fine:
<operationallayers>
MatthewStarr
I removed the info attributes.  cleared the Rest cache, cleared the Flex Cache and cleared the browser cache and for the Control Points I still only get the layer name in the identify results window.  For the parcels, which are not defined in the identify widget.xml i get all the fields.  I must be messing up the identify.xml I am just not connecting the problem.
Robert, Are you getting getting the Control Point fields to display? including the link?
If SO maybe I have not cleared out the caches properly...
Matt
