Link Widget
949
01-19-2012 08:03 AM
MartynSmith
Using robert's Link Widget, I'm wondering if there is a way or a workaround to just have the URL for the link in the main config.xml, instead of creating new linkwidget.xml files for each link.  I'm planning to use multiple link widgets representing a year (ie. 2011) with a list of dropdown links to tables representing each month, and creating linkwidget xmls for each seems redundant, when there is a URL field in the linkwidget configuration in the config.xml?
Robert, do you have any ideas?
RobertScheitlin__GISP
Martyn,
   Though I could make the flex viewer handle that it would involve manipulating the core flex viewer components and that does not make for a simple plug and play widget.
