Transparency when printing
3762
11-17-2014 07:36 AM
Ulises
Is there a way to control the transparency setting when printing?  The problem is that when the print page is generated with a selected polygon, there is no transparency at all, contrary to what you see in the map display.  This is a major drawback for us since users can't see thru the selected item and if there are adjacent polygons selected, users can't also identify the boundaries of each polygon.
Any help is greatly appreciated.
Ulises Feliciano Troche
RobertScheitlin__GISP
Ulises,
   Only the 3.6.9 and above versions of the eSearch widget will correct that issue.
Ulises what are you using to select the polygon, some widget, custom code?
Ulises
Sorry I missed that, Robert.  We use the eSearch widget.
Ulises,
Ulises
Thanks, Robert.  Will update the widget.
