TOC - Description
1448
04-24-2012 11:25 AM
EricVenden
I'm using the latest TOC widget (2.5.0.2) and have the "usenewesridescription" tag set to "false".  On a couple layers that are in the same "group" (see attached) I still get the "description" listing....Is this seen by anyone else?
Thanks for your time
Eric V
RobertScheitlin__GISP
Eric,
   What the "usenewesridescription" tag is for is once you click the description menu item it will go to the REST Service Directory (usenewesridescription = "true") or my popup dialog with the service metadata (usenewesridescription = "false").
Eric,
EricVenden
Thanks Robert,
I see that for those layers, I had something in the Description "field" for the layer property in the MXD
Eric
Eric,
