The �??coordinate system�?� of the map,
4488
12-27-2012 10:30 PM
JamalNUMAN
Legendary Contributor
I�??m not sure why the list of the coordinate system doesn�??t included all the coordinate system such that one can choose the prospective one! For example, I need to let the coordinate system to appear with the coordinate system of �??Palestine -1923-Palestine-Grid�?�. Is this still possible?
[ATTACH=CONFIG]20240[/ATTACH], [ATTACH=CONFIG]20241[/ATTACH]
Is there a work around for this issue?
Thank you
Best
Jamal
Jamal Numan
JasonDoss
Jamal,
     I came across this post while trying to figure out how to show coordinates at the bottom of the map in the Silverlight Viewer. I see you have done so in your attached jpg. Could you let me know how you did this?
JamalNUMAN
We no longer use the Flex as web mapping application. We switched to Geocortex. I forgot even how to show the coordinate in the Flex
Apologies Doss…
Jamal Numan
