Table of Contents - Legend Widget for FlexViewer 2.x
187032
664
12-01-2010 07:30 AM
RobertScheitlin__GISP
All,
Here is the next in my line of widgets for the FlexViewer 2.x.
The legend portion of this widget is the same code as my dynamic legend widget so,
IT IS FOR ARCGIS SERVER 10 OR GREATER ONLY
This is just a simple TOC Widget that includes my dynamic legend component.
This widget also includes my enhancement for map service transparency,
right click context menu for zoom to make layer visible, and my scale
dependent renderer for the TOC checkboxes.
Ajay,
   The current version does not work with secured services but hopefully the next version with resolve this.
AjayArcot
Thanks Robert, any idea when the new version will be released, or if there is an alternative I can use in the interim for Flex V2.4?
Ajay,
   Give this compiled version a test drive and see if it fixes the issue. No guarantees as I don't use secure services, thus have no ability to test myself.
JamesKo
Hi Robert,
Yes, that's correct the first layer does not have a description before I expand the node. I've noticed this behaviour on your site in the code gallery as well.
When I click on it, the tooltip disappears but it looks like it disappears eventually after 10 seconds or so.
TomSellsted
Greetings Robert!
I am having a problem with the TOC displaying properly with one of my map services.  http://gis.ci.yakima.wa.us/CityGIS/rest/services/PlanningDepartment/MapServer  All of my other services work properly except this one.  When I try to toggle layers they won't turn on.  It doesn't display a legend and eventually it starts making any other widgets behavior wacky too.
Could it be the symbology that I am using?  I would appreciate any advice you could give.
Thanks very much!
Regards,
Tom
Tom,
   I will look into it but I can tell you right off that it will help greatly if you start applying service packs. ArcGIS Server is currently on SP3 and you are currently on NONE.
EamonnDoyle
Hi There
Is there a way in this Widget, or another one, of creating Group's for Feature Services in the xml? Feature Services get published as individual Layers and I'm looking for a way to Group them into topics.
Eamonn
Eamonn,
   No, there has been several that have asked about this but the Level of Effort is just not worth while for this capability.
James,
  Thanks for the bug report it is fixed for the version 2.5 release.
ConejeSapiens
Hi Robert,
this is one of the coolest widgets in the code gallery.
I wonder where I can change the position of the Details Window, so that they appear in a corner of the screen instead that in the middle. Could you help me?
thanks!!
