Table of Contents - Legend Widget for FlexViewer 2.x
186975
664
12-01-2010 07:30 AM
RobertScheitlin__GISP
All,
Here is the next in my line of widgets for the FlexViewer 2.x.
The legend portion of this widget is the same code as my dynamic legend widget so,
IT IS FOR ARCGIS SERVER 10 OR GREATER ONLY
This is just a simple TOC Widget that includes my dynamic legend component.
This widget also includes my enhancement for map service transparency,
right click context menu for zoom to make layer visible, and my scale
dependent renderer for the TOC checkboxes.
Karl,
  In my legend it shows like that because it is a RasterCatalog and not an individual raster.
KarlWilson
Thanks Robert,
So apart from putting my images in a Raster Catalog, I guess there's no way of stopping the Legend displaying the RGB colours?
JamesKo
Hi Robert,
I think I may have found a bug. It only happens when you expand the first item in the toc. The metadatatooltip pops up when it shouldn't or at least I think it shouldn't.
Regards,
James
AjayArcot
I am having some issues, the TOC comes up with the layers but without the associated symbology.. And the "Generating TOC Legend" keeps on running, any help on this? Thanks
Aj
Ajay,
   And you are using ArcGIS Server 10 and above as the details state are required right?
James,
   So the first layer in the TOC does not have a description (metadata) button before you click the expand node and then it does? When you click on it what happens?
Karl,
  Correct as the RGB is the correct legend that should be displaying.
AjayArcot
Hi Robert, yes we are using server V10 with SP2, I have tried using single layers (services) at a time still the problem is there.. Thanks for your time on this.
Regards Ajay
Ajay,
   Can you post your config.xml and your TOCWidget.xml?
AjayArcot
Hi Robert, the config & TOCwidget xmls' are attached. Please let me know if I have missed something. Regards Ajay
