Standart draw widget. Error when measuring
2245
6
06-19-2012 01:45 AM
VladislavMasatin
Have updated FW to 3.0 version. After that then I'm trying to measure something, I'm getting error:
[FaultEvent fault=[RPC Fault faultString="HTTP request error" faultCode="Server.Error.Request" faultDetail="Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"]. URL: http://gis.astk.ee/project"] messageId="0B76E41A-B91A-710D-223D-03D6AE68E31E" type="fault" bubbles=false cancelable=true eventPhase=2]
How to solve this problem.
Server 9.3.1
DasaPaddock
What is the url for the geometryservice tag in your config.xml?
e.g.
<geometryservice url="http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"/>
VladislavMasatin
Don't use  geometryservice tag. FV2.5 also working without  geometryservice tag peerfectly.
<?xml version="1.0"?>
<configuration label="Draw and measure">
    <distanceunits>
        <distanceunit abbr="m" conversion="1">Meetrid</distanceunit>
  <distanceunit abbr="km" conversion=".001">Kilomeetrid</distanceunit>
    </distanceunits>
    <areaunits>
  <areaunit abbr="sq km" conversion="0.000001">Ruut kilomeetrid</areaunit>
  <areaunit abbr="ha" conversion="0.0001">Hektarid</areaunit>
        <areaunit abbr="sq m" conversion="1">Ruut meetrid</areaunit>
    </areaunits>
</configuration>
VladislavMasatin
Have found in ArcCatalog Geometry Service, copied URL under the service properties selection, but same error
http://***.****.**/arcgis/services/Geometry/GeometryServer
same story with
http://***.****.**/ArcGIS/rest/services/Geometry/GeometryServer
URL.
DasaPaddock
Measuring is working for me at:
http://resources.arcgis.com/en/help/flex-viewer/live/index.html
Can you share the contents of your config.xml?
VladislavMasatin
PM sended with code
Have tryed copy swf and xml files from 2.5 version, but the dont work at all. Widget is loading, but the drawing dissapear when I release mouse button. Measuring also not working, however no error window.
VladislavMasatin
Solved.
Reinstalled FV, rechecked config.xml, added geometryservice tag, restarted server and its working now. Seems that it was some bug somewhere.
Thanx for helping.
